Hi,
is there a way to use a Z probe via the A5 pin? It would enable some kind of better focussing.
Thanks, Rob.
Hi,
Thanks, Rob.
How would you touch the z probe… A spindle has a metal bit to complete the connection.
You wouldn’t touch it, you’d just mount a small limit switch to a post / pin, or use a beam break, or any other standard way that auto focus units work on a laser.
Thank you. Makes sense
There are mechanical probes which act like end stops I would use.
