Hello laser people, I’m in the process of building my first z table…
My question to you knowledgeable lot is do I need to change/adjust any settings in lightburn, say for the pitch of my lead screws.
I’ve got a extended bed k40,running a cluster smoothie cohesion 3d mini. And the z table is attached to the stepper driver set at 2 amps going to a nema23 stepper.
All of those settings would be in the Smoothieware configuration. LightBurn sends GCode in “real units” like mm. The controller translates those units into steps, so it needs to know the conversion numbers.
