Z-Tech Fiber Laser Compatibility
Hi, has anyone here successfully used LB with a Z-Tech fiber laser? I have tried too many methods to even list but still no success.
Most Z-Tech lasers use either EzCad2 or EzCad3, and the setup can be slightly different between the two, but they use the same driver.
Are you able to get LightBurn to connect to your laser at all? Or, once connected, your laser doesn’t perform as you’d expect?
Have you done the legacy driver swap as shown in our documentation here?
On that same page, there is also a section that will show you how to verify that your driver was correctly installed.
*(Page linked above: Legacy Zadig-Based Driver Swap)*
