ZAxis won't stop homing
Disclosure: I replaced the X axis stepper motor with a closed loop motor and driver. This required removing all the X gantry cabling to refeed into a larger cable guide. I had previously cut off the Z axis AF stop probe and removed the cabling completely during this upgrade.
Prior to the upgrade, on power up, the controller would home X and Y, then ‘buzz’ the Z axis momentarily.
Now the X and Y home but the Z then just keeps raising the bed. I hit cancel on the controller to stop it and then can use the laser. If I didn’t cancel I’m sure it would just continue raising the bed until it crashed the head.
I’m pretty sure I got all the cabling correct, the X and Y work great, Z can be controlled just fine too. It’s just the startup homing I need to disable.
I have tried disabling Z homing in both Light burn and RDWorks, but the controller insists on homing despite all signs saying it’s disabled.
What am I missing?
It’s an OMTech 80W AF with 6442 controller.
Perhaps the controller’s Enable Homing switch for the Z (or U, in my machine) axis must be turned off.
However, having that switch turned on does not cause my machine to home the U axis at startup, even though the autofocus button on the console works fine.
Try turning it off and see what happens: Edit → Machine Settings → Vendor Settings gets you there.
Both are set to off. Interestingly I had to use RDWorks to write that setting back to the controller, Lightburn didn’t actually do it.
Apparently Ruida controllers have settings invisible to LightBurn (and, presumably, RDWorks) for functions that should be controlled by the visible switches, but aren’t.
Enough to make you pound your head on the table …
