[Oz] Added ‘Repeat Marking’ feature for galvos
[Oz] Added Scale nudge to galvo framing dialog with PgUp / PgDn
[AH] Add File > New Window option to launch separate instance
[Oz] Added warp tool
[Oz] Added deform tool
[Oz] Line tool now actively tries to connect to existing shapes
[Oz] Cleaner output when deleting single line/curve in a shape
[Oz] Auto-close combined paths in SVGs on import
[Oz] Add head camera settings to camera import/export
[Oz] Added field offset for fine tuning galvo devices
[Oz] Added cursors to indicate failure modes for Fillet tool
[Oz] Updated Slot resizer to support Inch units
[Oz] Allow two decimal places for Q-pulse length for UV galvos
[Oz] Added Done Marking duration setting
[Oz] Remember the Job Counter value after the framing dialog is closed (might move this to a global counter, but trying this for now)
[Oz] Can now drag-reorder stored move coordinates
[Oz] Expanded range of allowed override frequency for CO2 lasers up to 100khz
[Oz] Don’t allow MOPA commands through to DIGIT boards (prevents hanging the board when wrong laser is chosen)
[Oz] Bugfix: SVGs with shape instances that specified size in percent imported incorrectly
[Oz] Bugfix: Don’t print hidden layers
[Oz] Bugfix: Variable text parser would miss quotes on start of line
[Oz] Bugfix: New auto-overscan code for DSPs ignored multiple passes
[Oz] Bugfix: properly handle multi-appended SVG style definitions (new Illustrator exports & clipboard format)
[Oz] Bugfix: large data packets sent from Ortur WIFI (like machine settings) could hang the connection
[Oz] Bugfix: support height wasn’t properly restored when switching between mm/in on the main toolbar
[Oz] Bugfix: DXF polyline arc export was incorrect for some device origin settings
[Oz] Produce less direction change in Offset Fill of curves
[Oz] Bugfix: Done Marking signal for galvos wasn’t properly emitted when a job completed normally
[Oz] Bugfix: Overscan distance wasn’t shown properly for Image Mode on GCode systems
[Oz] Bugfix: Enable Focus / Air assist by layer/with laser settings interfered with each other
[Oz] Bugfix: Overcut used with “Choose best starting point” on Ruida could produce an incorrect cutting line
[Oz] Bugfix: GCode produced for non-horizontal fills on A-axis rotary had incorrect feed-rate
[Oz] Bugfix: Flood Fill now disables Fill grouping in galvo mode
[Oz] Bugfix: ‘Show Me’ open shapes would crash if the shapes were in a virtual array
[Oz] Bugfix: Pause button in rotary screen would sometimes not resume
[Oz] Bugfix: Image compositor could sometimes output zero-length pixels on the edge of an image
[Oz] Bugfix: ‘Start Here’ + Overcut would emit incorrect cut line at end on GCode systems
[Oz] Bugfix: AutoGroup feature could incorrectly exclude interior shapes
[Oz] Bugfix: don’t do extra work during ‘Break Shapes’ (dramatically faster when breaking shapes with lots of nodes)
[Oz] Bugfix: PDF file with a line-break in an object reference would crash
[Oz] Bugfix: Scan image preview showed wrong angle for some device origins
[Oz] Bugfix: Ramp mode broken if “ramp outer edge” was off (bug in inside/outside sorting)
[Oz] Bugfix: Disabling first sub-layer could cause a crash, and incorrect filling of subsequent sub-layers
[Oz] Bugfix: Slicing shapes for rotary could cause a crash in rare circumstances
[Oz] Bugfix: Limit total attempts to intersect Bezier curves (prevents crash on malformed or weird files)
[Oz] Bugfix: Roller rotary on galvo was incorrectly using object diameter, not roller diameter
[Oz] Bugfix: inline style should override class style on shapes
[Oz] Bugfix: Send File shortcut (Alt+Shift+S) was broken
[Oz] Bugfix: ‘Mirror output to rotary’ would revert if creating or loading a new file
[Oz] Bugfix: DXF spline parser got confused if some data fields were out of order
