Zero Point Rotary Setup
Hey there, i know this question may get asked a lot but i couldn’t find the right post yet.
I have a rotary setup on my Ortur LM2 S2 and i need to know how to set my zero point anywhere on the drum. The laser thinks i am out of the maschine space, when it isn’t bc i moved it by hand. and i dont know how to fix it.
thank you and sorry for the bad english, i am german
Change the Start From: to “Current Position” and manually move the laser head to the point you want the laser to start. You are correct, since you moved the laser head manually it doesn’t know where it is. Just ignore the out of bounds message as long as your sure the cut will not exceed the limits of your machine. You can also turn off this message under device settings
thanks, problem solved
