Hey folks, this is a strange one, I have the Ortur Laser Master Pro 2 (S2) that comes with the 10W LU2-10A.
It’s been running fine until I upgraded to the latest firmware (as I bought the enclosure with the fan and light)
Since then I’ve noticed that the cuts have been a lot less powerful, at first I thought it was because the unit was powering both the fan and light so I moved them onto a separate circuit but no difference,
I then thought it could be a dusty lease so I took some cotton buds and alcohol and did a bit of cleaning, no difference
Finally I added an air compressor with air assist but it doesn’t seem to have made much difference.
Here is a LightBurn materials test a few days ago on 3mm plywood
Now if these results are what is to be expected for these materials (and we just had to burn the laser in) then that’s great but I just wanted to make sure I’m not missing anything or I’ve forgotten a step in my debug process?
I’m ignoring the burn marks around the engraving but it’s more the cutting power has reduced dramatically, if these results for 3mm ply for this laser are expected then I can work with it but it’s just the dropoff from that first picture is a fair amount.
Is the air assist being used in both material tests shown in your last post?
Air assist can reduce the scattering of the laser from smoke and debris. It makes very clean cuts and allows higher cutting speeds or lower power levels to be used.
I’ve just run another one without the compressor attached and here are the two together you can see that the cuts are a lot nicer but still much less power than last week?
the light is still on, there hasn’t been any cracks or bangs of it, I don’t have a spare to test though, Happy to order one and see if that makes a difference but I get the feeling I’m getting close to a Ortur support ticket.
