100% Busy PLEASE HELP
Tried everything! Still 100% busy…
Drivers installed ok.
tried $# with no response
Any help would be greatly apricated
Hi, try right clicking the ‘devices’ button at the bottom of page on the right
Still 100 % when I go to home
Try turning it off and turn off the computer,
turn the laser power back on followed by the computer.
If the computer is turned on first it doesn’t always connect.
If that doesn’t work check all the cable connections.
Thank you, let me try this…
Didn’t work. I powered up the laser, plugged it the UBS cable then powered up my computer, right clicked devices with no luck… :rofl:
all cables are good…
Do you see anything at all in the console window? Have you chosen a COM port?
