3018 laser is fine in lasergrbl, but nothing in lightburn
Not having much luck with lightburn, any hints?
Starting with this will help you get the best possible responses.
If you want to look for answers that may have already addressed your issue, we offer a search tool at the top right of every page.
https://forum.lightburnsoftware.com/search?q=3018
Lots of them: Configuring a 3018 CNC for use with LightBurn
Most likely you’re trying to go faster than the machine limits allow, so it’s cutting the power. (see about 1/2 way down in the above page)
Wow, setting overload. Looks like I’m getting it figured out now, I had read through those links before, but misunderstood and set things wrong. After re-reading a half dozen times, I’m finally burning
There’s a learning curve, for sure. The 3018’s are not terribly well suited for laser use because the lead screws make them quite slow, but they work.
