3d printer mks tinybee with laser and cnc machine possible?
Hello. I want to make a 3 in 1 system. (3D printer, Laser and CNC router) There is MKS DLC32 v2.1 on the machine. But this card does not support the 3D printer. Instead, I want to use all 3 systems on the same card. Can you recommend a card that supports this? If possible, it could be MKS brand. They told me that mks tinybee supports all three. But I am not sure about this.
It’s mainly a firmware thing. Marlin can run both a laser and a printer. I guess also CNC, but I don’t know.
But in general, that is not the best idea. Those machines have contradictory requirements, that’s why you don’t see many of those machines.
  • a laser needs high speeds and less torque mechanics
  • a CNC needs high torque and slow speed mechanics
  • a 3D printer needs z-axis accuracy that a laser doesn’t need at all
If you put all in one, you will get a machine that is worse in any scenario.
Thank you.
