Hi Guys, what are your cutting settings for 6mm MDF board in 22W algolaser? I tried different pass and different power/speed, but it is still burning. I have air assist as well
Does your laser have air assist? I makes a dramatic difference when cutting.
Also, are you trying to cut it in a single pass? Try speeding it up and using 6-8 passes.
I tried 1 to 3 pass, still burn or not cut. yes, I have air assist and my lens are clean
To get a reliable cut on 8mm bamboo with a 40w laser, I have made up to 20 passes. In my defense, 20 passes with a 40w CO2 laser did not get through. More passes is not necessarily a bad thing.
Try sub-layers
Thanks Fernando. Just to clarify, i will create 3 sublayers. All settings are 950mm/m and 97.5% power?
You could use less power, if you have a simple webcam pointed sideways to the job you could see when it’s cut (the laser light appears under the honeycomb) and let say if at the end of the 2nd sub-layer cut it’s cutted you can stop the job).
I always set 9 sub-layers and follow the job.
