For X axis the LSB controls direction – 0 or 1
For Y axis, next bit left of LSB – 0 or 1
So, $3 will be 00, 01, 10, or 11… i.e. $3=0/1/2/3
$3 – Direction port invert, mask
This setting inverts the direction signal for each axis. By default, Grbl assumes that the axes move in a positive direction when the direction pin signal is low, and a negative direction when the pin is high. Often, axes don’t move this way with some machines. This setting will invert the direction pin signal for those axes that move the opposite way.
This invert mask setting works exactly like the step port invert mask and stores which axes to invert as bit flags. To configure this setting, you simply need to send the value for the axes you want to invert. Use the table above. For example, if want to invert the Y axis direction only, you’d send $3=2 to Grbl and the setting should now read $3=2 (dir port invert mask:00000010)
One thing I’m noticing in the test burn is that the start/end and corners of the design seem to be burned. Are you running with “Constant power mode” or have you possibly configured the machine as “GRBL-M3”? I would expect laser mode and variable power to eliminate or at least reduce that.
Is there anything in Console when that happens? What do you need to do to recover?
mine did the same, but I couldn’t connect to either the ‘upgrade’ or Lightburn programs after doing it once.
I got my programmer and loaded it via the internal header, had a successful ‘load’ but it’s still unresponsive to the any program… Makes no announcement of the firmware.
Jack, it appears that you are not connected… so $$ won’t work. I don’t think the “Ready” at top of Laser tab is a reliable indicator… but the Console window is.
One thing I’ve noticed with my Linux-enabled Chromebook… every time I power down or disconnect, the “ttyUSBx” setting “toggles” to another setting. If I click on the “port” field it usually shows me a different setting… select it and I’m able to connect.
Even if I don’t set it, when I right click on the device tab it finds it… Generally it doesn’t say ‘ready’ but with it set to plain grbl it does say it’s ‘ready’… however they determine it, it must be there.
I only have a few things on that hub and I can see the 340 driver in lsusb…
