I donāt know if yours were done with Dot Mode, but, if not, itād certainly be worth trying to see if it looks better. Then we can compare results and maybe reach some conclusions.
Some background and other power variations on my blog:
Hi Ed, thanks for the image. Those marks a far more consistent than mine. Iām just checking into all the information that Jack provided regarding the limitations that the laser firing speed imposes.
Thanks Jack. The thread has been moved. I understand your thinking on the laser firing speed. Just taken the machine to bits so I can see all the various components and get some specs. It is an Oculus 6040 (600mm x 400mm bed) from OPUS CNC based up in Durham, England. Itās a bench top, but you need one heck of bench, it weighs more than 300kg. Thanks for pointing me to what will clearly limit potential resolution. The speed for the dot test was 100mm per second. Do you think the 0.05mm diameter dots indicate that the 6040 can resolve a 0.05mm dot and retain a 0.05mm gap, but obviously not consistently? In the manual it recommends a line interval setting of 0.035 for raster engraving images on acrylic. Thanks again.
You canāt really tell what kind of a dot you can make if the machine isnāt operating correctly. Yours is clearly got an issue with itās optics/sourceā¦
The ramp test isnāt bad, but the output of these dots look unfocused.
Donāt know where you got your sourceā¦ or how itās configuredā¦ but here is a dot test from Russ Sadler and how to interpret itā¦ Itās under the heading Interpreting The Dot Size Test results
It turns out the power supply puts a rather low limit on the overall response time, on the order of 250 Hz for PWM input. Thatās not the PWM carrier frequency, which is typically 20 kHz for Ruida controllers, but the rate at which the laser power can change.
The overall risetime is around 1.5 ms, so the dots canāt be much less than 4 ms āwideā to have reasonably steep sides and a flattish top. That means a 0.05 mm dot requires a scanning speed around:
12.5 mm/s = 0.05 mm / 4 ms
Which is sufficiently lethargic to incinerate anything youāre likely to be engraving and so slow youāre likely to not believe it.
I didnāt believe it, either, so here are the measurements & pix:
The linkies there take you to the background on the test setup & suchlike; it took me a while to work around to those conclusions.
So a COā laser can produce high resolution images and run at high speeds, just not both at the same time.
OPUS are also running test on another 6040, same material same test files. Should hear from them a bit later.
Iām using Lightburn Ed, does this have ādot modeā? I canāt seem to find that. It does provide āThresholdā which is either on or off for black or white.
Iāve checked the laser power supply, Model: HY-T80 so Response Speed is ā¤1ms to 90% of set power. Should be able to run at 200mm/s by Garethās info, maybe up to 400mm/s.
The Ruida Controller is model RDC6442G-B.
Going see what some slate engravings look like at 127dpi.
Itās a good technique for producing controlled burns (or dotted lines!) at much lower power than a normal vector can achieve, at the cost of running around 5 mm/s no matter what speed the layer calls for.
Hi Gentlemen. These are my latest results. Having read your suggestions Jack, I thought I would check everything. The laser tube was not secure in its mounts, so sorted that and ended up with better alignment from Tube to M1 anyway, it was always slightly high. Then a I recalibrated M1, M2 & M3. The first result is the is Garethās dot test run on card. The second is a grey scale test run at a line interval of 0.15mm.
Clearly the non secure tube was an issue. Using Garethās guidance would you say that a line interval of 0.15mm is the best resolution on this device? Iām thinking the dot size and therefore line interval is less than 0.2mm but more than 0.1. My only other thought is that the lines are defo not touching on the greyscale test, which would indicate slightly higher resolution would be available on the anodised alloy business cards. Also, do you think the burn marks are about right for a CO2 gantry laser? The diode Galvo seem far better and more consistent.
I would think this is evident of issues with the Y axes (assuming X is horizontal) being lose or incorrectly adjustedā¦ It could be a grub screw coming lose or some other mechanical anomaly.
Or a loose lens, as happened with somebody else in recent memory. Youād never notice anything along the X axis, but any motion in Y would produce those worms.
If the lens is wobbling around while traveling parallel to the X axis, any motion in the X direction will be pretty much invisible: if the beam goes backwards or forwards, the trace will be marginally lighter or darker.
But if it wobbles in the Y direction, then the beam will burn to one side or the other of the center line where it should be, which could produce those worms.
Come to think of it, in Dot Mode a wobble in the X direction could produce irregular dot spacing, which is kinda-sorta what appears in the bottom track.
Iām not convinced, but itās certainly worth checking all the doohickies on the laser head for a snug fit.
Iām so glad you guys have raised the worm issue. I have no experience with lasers at all and donāt know what I should be expecting in terms of results. To give perspective the laser was Ā£6k Sterling and it was new March 2022. However, I have not started using until about 4 weeks ago and was immediately struck by lack of quality on attempting to picture engraving.
I will investigate the mechanical setup further. Thereās no way I would have know that the wobble you refer to should not be an expected result. I would have put it down to units limitations. Really appreciate your input. Thanks.
This one was done on the fiberā¦ this has a smaller dot, but the material, is generally the what sets the dpi limit ā¦ in the end it will be laser dot size and material that will decide the best dpi.
Given a loose tube rattling around in the back, it should be awful.
With that snugged down, the results look pretty good and weāre quibbling about details.
The scan interval depends on the width of the surface damage in the target: 0.15 mm is an itsy too wide for the grayscale material, but might work fine in a different material.
At some point you should explore Dot Width Correction for images; I donāt have a lot of experience, but itās apparently the ticket for crisping up the contrast:
This laser everything video talks to the Lightburn developer of dot width adjust at about 20:18 into the videoā¦ good explanationā¦ also a very good video on how to set up the proper dpi for a any given material/laser.
