Hi there!
So I’ve been using Lightburn with my K40 and GRBL-LPC to great success, mostly, but since I’ve ruined two more cutting boards, I figured I might ask for help.
As referenced here # A G-code word was repeated in the block there seems to be a bug in the .24 version, that causes random stops. Currently using the linux version.
Since I was afraid it might be a grounding issue or the like, I started the same engraving process again - and it stopped at the exact same point.
The first few lines are engraved nicely, then there’s a few lines skipped and a shift of a about two centimeters to the right, and then the cutter stops altogether with error “A G-code word was repeated in the block”.
It would be great to have a new release, or access to a beta of some sort, if there’s a major change holding up the release.
Thanks.
