Hi, is there a way to set smaller intervals for example 0.1mm when you move the laser with ctrl.
I have problems adjusting the targets in print and cut and I need smaller intervals
Thanks, but you have not understood me, that screen is to adjust the displacement of objects on the screen, what I want is to adjust the displacement of the laser head, I know that in the Laser tab there is a parameter called distance that does that, I want the same but when you press ctrl
I just type the absolute value I want to move in the movement quadrant.
It could do with work - like remaining in focus in the axis you’re moving and allowing enter to execute the move instead of moving focus to ‘Go’.
Maybe I am not understanding either, but are you talking about the programmable distance for each key press using the arrows in the ‘Move’ window?
If you press Shift, it multiplies the move distance by 5.
If you press Ctrl, it divides it by 5.
Pressing Ctrl+Shift divides it by 10.
Pressing Alt divides it by 50.
So, if your move distance is 10mm:
| Modifier keys | distance moved |
| None | 10mm |
| Shift | 50mm |
| Ctrl | 2mm |
| Ctrl+Shift | 1mm |
| Alt | 0.2mm |
OK, many thanks
