Alarm 1&3 mit LightBurn (Alarm 1&3 with LightBurn)
Hallo bin Anfänger und hoffe auf Hilfe. Habe einen Snapmaker Ray. Mit Luban kann ich Jobs starten aber nicht mit Lightburn siehe Fehlermeldung.
Hello, I’m a beginner and hope for help. I have a Snapmaker Ray. I can start jobs with Luban but not with Lightburn, see error message.
Auf Verbindung warten …
Datei in 0 Millisekunden importiert
�!�ā�Ł�5%�����5���!�ā�!�ok
ok
[VER:V1.7.4.20240702:]
[OPT:PHSW]
[I][PLAT]Machine: Snapmaker Ray Controller
[I][WIFI]Mode=STA:SSID=KingMarvin:Status=Connected:IP=192.168.1.123:MAC=34-85-18-91-16-70
ok
<Idle|MPos:0.000,0.000,0.000,0.000|FS:0,0|WCO:0.000,0.000,0.000,0.000>
ok
ok
[I][PLAT]reset sys pos and WCO because disabling motor
[I][PLAT]reset coordoffset
Stream wird gestartet
[I][PLAT]Program End
Stream fertiggestellt in 0:01
ok
ok
ok
Stream fertiggestellt in 0:00
[I][PLAT]Check limits
[I][PLAT]‘$H’|‘$X’ to unlock
ALARM:3
In Bewegung zurücksetzen. Grbl kann die Position nicht garantieren. Verlorene Schritte sind wahrscheinlich. Die Rückkehr zur Ausgangsposition wird dringend empfohlen.
Reset in motion. Grbl cannot guarantee the position. Lost steps are likely. Returning to the starting position is strongly recommended.
[I][PLAT]Caution: Unlocked
ALARM:1
Harte Grenze ausgelöst. Die Maschinenposition geht wahrscheinlich durch plötzliches und sofortiges Anhalten verloren. Die Rückkehr zur Ausgangsposition wird dringend empfohlen.
Hard limit triggered. The machine position is likely to be lost due to sudden and immediate stopping. Returning to the starting position is strongly recommended.
[I][PLAT]Reset to continue
[I][PLAT]max rpm: 1000
ok
ALARM:3
error:22
Vorschubrate wurde noch nicht eingestellt oder ist nicht definiert.
Feed rate has not yet been set or is not defined.
[G54:0.000,0.000,0.000,0.000]
[G55:0.000,0.000,0.000,0.000]
[G56:0.000,0.000,0.000,0.000]
[G57:0.000,0.000,0.000,0.000]
[G58:0.000,0.000,0.000,0.000]
[G59:0.000,0.000,0.000,0.000]
[G28:0.000,0.000,0.000,0.000]
[G30:0.000,0.000,0.000,0.000]
[G92:0.000,0.000,0.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000,0.000:0]
ok
[I][PLAT]max rpm: 0
ALARM:1
[I][PLAT]max rpm: 0
Vielen Dank schon mal für eure Unterstützung
Thank you in advance for your support
If you click the automatically hyperlinked text, it will take you to the information you need to solve the issue.
ALARM:1
ALARM:3
Hallo Colin
Danke für deine Antwort, aber ich konnte das Problem bisher nicht lösen.
Thank you for your answer, but I have not been able to solve the problem so far.
Wann genau kommen die Fehler? Mach mal einen Screenshot vom LightBurn-Fenster.
When exactly do the errors occur? Take a screenshot of the LightBurn window.
Referenzfahrt funktioniert wenn ich einen Rahmen fahre Fehler
Homing works when I drive a frame Error
ich kann den Laser auch bewegen (XY 100mm) wenn ich die Position abrufe ist XY 0
I can also move the laser (XY 100mm) when I call up the position, XY is 0
Hat der Snapmaker seinen Ursprung wirklich oben links? Normalerweise haben fast alle Laser den Ursprung unten-links.
Does the Snapmaker really originate from the top left? Normally, almost all lasers have their origin at the bottom left.
da bin ich nicht sicher die Referenzfahrt ist nach oben (hinten) links
I’m not sure, the reference run is to the top (rear) left
das Problem muss bei Y liegen. Zu Pos. X 100 gehen funktioniert Zu Pos Y 100 wird in Lightburn angezeit der Laser fährt aber in die andere Richtung und prduziert Alarm 3
The problem must be with Y. Moving to position X 100 works Moving to position Y 100 is timed in Lightburn but the laser moves in the other direction and generates alarm 3
Try changing the origin to bottom left.see box marked B on picture.
habe ich gemacht aber die Y-Achse fährt immer noch in die falsche Richtung
I have done this but the Y-axis is still moving in the wrong direction
Interesting. Did you set up your machine using the .lbdev file from snapmaker?ifound this on their website. Using Ray/Artisan/2.0 with LightBurn | Snapmaker Wiki
Keeping front left origin close restart Lightburn and power cycle your system/laser.
After enable pointer offset.
ja habe ich vom snapmaker support bekommen
yes i got it from snapmaker support snapmaker-ray-40w-v1.lbdev
wenn ich mit den Pfeiltasten verschiebe passt das jetzt zur Y Bewegung. Aber wenn ich XY referenziere fährt der laser nach oben links und in lightburn ist die position unten links
If I move with the arrow keys it now matches the Y movement. But when I reference XY the laser moves to the top left and in lightburn the position is bottom left
Dann in LB wieder umstellen auf oben links. Dann sollte doch alles passen?
Then switch back to top left in LB. Then everything should fit?
Your squares plus the laser offset get near X0 position
Solution to try:
Set Job Offset Mode in Luban to Laser spot.
In Lightburn disable pointer offset and origin to front left.
Run the job again.
Good luck.
I can’t find it can you show me where to do it in luban thanks for your support
das Problem ist immer noch da. “Laserpunkt” ist eine Jobeinstellung in luban, hat aber keine Auswirkiung auf lightburn
the problem is still there. “Laser point” is a job setting in luban, but has no effect on LightBurn
Welches Problem genau? Die Bewegung per Tasten funktioniert? Dann musst du ja noch noch die Home-Position richtig eingeben, oder?
