This is a screen shot of the Move panel. Seems the distance option is not activated.
You have continuous jog enabled
also in console can you type $# press enter
Send image of the output please?
Go to Edit > Device Settings. In the upper-left of that window, what corner is the ‘Origin’ dot set to? It should be the lower left.
Turning off continuous jog did the trick! I feel so dumb. I run a cnc machine and have worked with plotters for 6 years now, should have figured it out. Orgin is bottom left. I am attaching the $# just to be sure. Thank you!
[G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G92:0.000,0.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
