Alarm 2 G-code motion target exceeds
Hello, I have been reading and trying all of the great advice you have given for this horrible Alarm:2 unfortunately, I am 4 hours in with a bran new machine that Ii get to do much of anything. I take that back. I was able to get it to center on my surface but then… nothing. Here is the code I am receiving the following. Please help if you can. Thank you ~ LJohnson
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 4:
Job halted
Stream completed in 0:00
[MSG:Reset to continue]
ok
Grbl 1.1f [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
jone00[MSG:Caution: Unlocked]
ok
<Idle|MPos:0.000,0.000,0.000|FS:0,0|WCO:0.000,0.000,0.000>
ok
Starting stream
ALARM:2
On or near line 2:
ok
ok
This alarm is given when the cut you’ve commanded exceeds the travel ability of your laser. This can sometimes happen when the origin is set incorrectly. Most Gcode machines use a front left origin, can you confirm your settings by going to 'Edit > Device Settings" and let us know what you have set for your origin point. Alternatively you could have part of your design outside the working area if that is correctly set.
As an example, here’s what I have for my Gcode machine (Front Left):
Ok, I changed the S-val max to 1000. It now moves freely but, it appear maybe my printable area is to large? It keep wanting to run thru the out parameter both at the home and the end areas.
Hi Colin,
So, I have been watching and search google for answers. I just found that when my laser is in the far left bottom, as far as it can go. It is not at 0,0. In fact the Xpos is 197.346 and Xpos is 208.018. It’s not at 0,0 at all and on the screen is looks like this. I am finally getting movement which is good but, it’s not working. Any ideas as what to do? It’s brand new out of the box.
If you type $$ into the console what do you get for $10? You will likely want to change it to $10=0. This sets your machine status reporting to be relative to the workspace origin, not the machine origin
See this for more details Common GRBL/GCode Setups - LightBurn Software Documentation
I change the $10=1 to $10=0. It is able to move but my laser location is way off. It want to run thru the bar.
When I clicked on the the laser position and selected the items. It moved to the far right corner of the laser all the way to the top and then proceeded to bounce off the edge. Then stopped.
Thank you, I feel like were getting somewhere. I changed all of the $$ to their recommendation but wasnt sure where to go to do this… see picture.
Turn the laser off, manually position the laser head at front left, and then turn it on.
Then go to your LightBurn>Window>Console, and enter these commands, one line at a time, and press “enter” after each:
$i
Copy/paste the results back here.
Then go to the Move window, and try jogging the laser to the diagonally opposite corner at the back-right, using the Y+ and X+ buttons. When you get as far as you can go and “Get Position”, what values do you see for X and Y?
Waiting for connection…
ok
ok
[VER:1.1f.20170801:]
[OPT:VZHL,15,128]
Target buffer size found
ok
Homing
ALARM:9
Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases.
ok
ok
Si
error:2
Numeric value format is not valid or missing an expected value.
$0=5
$1=250
$2=1
$3=1
$4=0
$5=0
$6=0
$10=0
$11=0.010
$12=0.002
$13=0
$20=1
$21=1
$22=1
$23=3
$24=5000.000
$25=5000.000
$26=250
$27=1.000
$30=1000
$31=0
$32=1
$100=80.000
$101=80.000
$102=80.000
$110=10000.000
$111=10000.000
$112=500.000
$120=1000.000
$121=1000.000
$122=10.000
$130=400.000
$131=400.000
$132=200.000
ok
[G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G92:0.000,0.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
<Idle|WPos:-600.000,-600.000,0.000|FS:0,0|WCO:0.000,0.000,0.000>
ok
Home:
x: -23.622 Y: -23.622 z: 0.000
Back Farthest Right:
X: -5.025 Y:-5.025
I would strongly recomend against changing GRBL values if you not sure what you are doing
$RST=*
Press enter
So all reset to factory defaults
notice
You are asking the machine to start CENTER center
However i can imagine you just homed mahine
So machine “THINKS” its at X0 Y0
You ask it to start from “CURRENT POSITION” therefore x0 y0
And go into negative X and Y at least 100mm
it wont do it, will alarm 2
If you want to do the above, i sugest you jog machine to X200 Y200 first
Dead ccenter
Then adjust it by hand. THEN use current positiong center center
I have no clue what I am doing? It is a brand new machine. I have only done what what asked of me here. I am a complete newbee with a machine new out of the box. I spent 6 hrs. on it yesterday just trying to get it to work with the codes I was told to put in here. So what am I suppose to do? I am super confused here.
I moved it by hand to get the position that I posted. If I tell it to home it tries to go past the bar literally, keeps going until I hit stop.
What i am sugesting is
You are asking the machine to do things, it cannot do
I would sugest starting in absolute coordenates first
Afterall you are - from what i could see - positioning your job in the grid. Assuming you want the job to be engrave there in the machine bed
When using current position or worse user defined, you must understand you are changing the coordenate system, and this has implications. specially on machines with homing, soft and hard limits.
So $RST=* all to defaults (type this in console and press enter)
then use Absolute coordentes, and try something simple, like a Box at x200 Y200. will it work?
right but the “machine brains” dont know that. so it thinks its still at where it was.
Machine has homing swtiches correct?
I closed out and restarted lightburn then typed $RST=* and this is what it said
ok
[OPT:VZHL,15,128]
ok
Homing
ALARM:9
ok
ok
$RST=*
[MSG:Restoring defaults]
ok
