I have a ORTUR laser master 2, every time I want it to Fram or start engraving I keep getting Alarm 2 (Reset to continue), the laser does not more but it says in the tap that the laser is busy, anyone know how to fix this?
ALARM:2 is an out-of-bounds condition. Are you running in ‘Absolute Coords’ mode? If not, you should be. If you are already using Absolute Coords, type $# into the console and press enter, then copy the output here so we can see it.
This was sorted out over email. He had chosen the ‘X-Carve’ option when setting up, and ended up with a workspace offset applied. Resetting the device setup and clearing the offset was the solution.
