Hello, while introducing the extension kit of my laser through the LightBurn program, I made a mistake and then the machine stopped working and the cyan light side did not react after the beep.
Try this for us
In console type
$RST=*
Press enter
Once done
Type
$131=800
Press enter
Then home machine again and try engrave
The machine does not turn on and does not connect to lightburn. I can send a video if you want
Could you upload it to youtube or a similar platform and post the link here?
Are you certain you plugged in both stepper motor cables?
As well as the syncro shaft is it fully tight?
Very strange. As nothing that you did in lightburn - per se - could have caused this issue
I think you nee to get in touch with support suppor@algoalser.com will help
ı will sende ticket thanks
DO you have any idea ? They can not answer quickly ı need to work.
