I am trying to engrave this with the blue layer filling all the color except stars, stripes and text but it wants to fill the entire image how do i stop this and tell it to avoid them areas
Try this and it will give you an idea how the fill logic works:
Select all (Ctrl-A) and duplicate your project (Ctrl-D). Now move this off to the side to experiment with.
Select all of the components of your flag and change everything to layer 01. Then preview. Now start there and see where that takes you.
(it should make something like this)
And if I use that same layer as an offset around the text:
Here is more info below (and searching or reading the docs provided by LightBurn will also help out)
