Anodized Aluminum Sheet Black 5005 Online, Thickness: 1/16" I know a person using Lightburn and a 7W JTech laser. The material is unaffected by that laser beam at 100% power and a speed of 1inch per minute. Has anyone else experienced such a thing and could they point me in the right direction to resolve the issue?
Here is something similar, as far as I can tell.
I think you will have to give us move information for us to give you much help. That’s assuming that particular anodizing is etchable with that wavelength laser.
Thanks for the response. I will check with the person for details of the anodizing. I have no problems so far and my laser is a JTech 4.2W 445nm diode laser.
It’s this product: Order 0.063" Anodized Aluminum Sheet Black 5005 Online, Thickness: 1/16"
The vendor says it’s not “hard anodized” nor UV protected. And it’s matte, not shiny. A sample has been sent to J Tech Photonics to see what they have to say.
J Tech got back to me. Here’s what they had to say:
“Thanks for sending over the anodization sample. I tried it out and you are correct, you can’t get it to engrave. My 100W CO2 laser barley can engrave it. It warped the metal because I was going slow on it and the heat it absorbed made it hot. The 7W Pro made a faint mark when the focus was perfect, but it mostly just heated up the metal. I think it unfortunately just doesn’t work that well on that particular anodization.”
I was suspicious that may have been the issue. Glad you have a good source to check with. Thanks for letting us know…
One of the issues with aluminum is it’s ability to sink heat, as the J Tech people stated.
Take care, good luck…
It would be good to know what the anodisation process was. I buy my anodised dog tags from the USA and they have always engraved without issue. It would be useful to find a pre-treatment if possible. I have been engraving a series of glazed ceramic tiles and a pre-treatment with flat white pain that I remove afterwards, with acetone, really helps the engraving process.
