Another Ortur 2 15w ALARM2 issue
So I engraved about 6 test patches and one successful patch using Lightburn with my new engraver I got today. Now, I get the dreadful Error 2 line 2 or 4 message. I also get the same error inside LaserGRBL software. I do not know what changed. I’ve posted my GCode below for a simple circle I’m trying to test with. When I do manage to bypass the error, the engraver no longer engraves, the light is on, but very weak.
; LightBurn 0.9.16
; GRBL device profile, absolute coords
; Bounds: X41 Y22 to X113 Y94
G00 G17 G40 G21 G54
G90
M4
; Cut @ 3000 mm/min, 50% power
M9
G0X54.1Y30.22
; Layer C00
G1X52.79Y31.35S500F3000
G1X51.54Y32.54
G1X50.35Y33.79
G1X49.22Y35.1
G1X48.15Y36.46
G1X47.15Y37.87
G1X46.21Y39.33
G1X45.35Y40.84
G1X44.55Y42.39
G1X43.83Y43.99
G1X43.18Y45.62
G1X42.62Y47.29
G1X42.13Y49
G1X41.73Y50.74
G1X41.41Y52.52
G1X41.19Y54.32
G1X41.05Y56.15
G1X41Y58
G1X41.05Y59.85
G1X41.19Y61.68
G1X41.41Y63.48
G1X41.73Y65.26
G1X42.13Y67
G1X42.62Y68.71
G1X43.18Y70.38
G1X43.83Y72.01
G1X44.55Y73.61
G1X45.35Y75.16
G1X46.21Y76.67
G1X47.15Y78.13
G1X48.15Y79.54
G1X49.22Y80.9
G1X50.35Y82.21
G1X51.54Y83.46
G1X52.79Y84.65
G1X54.1Y85.78
G1X55.46Y86.85
G1X56.87Y87.85
G1X58.33Y88.79
G1X59.84Y89.65
G1X61.39Y90.45
G1X62.99Y91.17
G1X64.62Y91.82
G1X66.29Y92.38
G1X68Y92.87
G1X69.74Y93.27
G1X71.52Y93.59
G1X73.32Y93.81
G1X75.15Y93.95
G1X77Y94
G1X78.85Y93.95
G1X80.68Y93.81
G1X82.48Y93.59
G1X84.26Y93.27
G1X86Y92.87
G1X87.71Y92.38
G1X89.38Y91.82
G1X91.01Y91.17
G1X92.61Y90.45
G1X94.16Y89.65
G1X95.67Y88.79
G1X97.13Y87.85
G1X98.54Y86.85
G1X99.9Y85.78
G1X101.21Y84.65
G1X102.46Y83.46
G1X103.65Y82.21
G1X104.78Y80.9
G1X105.85Y79.54
G1X106.85Y78.13
G1X107.79Y76.67
G1X108.65Y75.16
G1X109.45Y73.61
G1X110.17Y72.01
G1X110.82Y70.38
G1X111.38Y68.71
G1X111.87Y67
G1X112.27Y65.26
G1X112.59Y63.48
G1X112.81Y61.68
G1X112.95Y59.85
G1X113Y58
G1X112.95Y56.15
G1X112.81Y54.32
G1X112.59Y52.52
G1X112.27Y50.74
G1X111.87Y49
G1X111.38Y47.29
G1X110.82Y45.62
G1X110.17Y43.99
G1X109.45Y42.39
G1X108.65Y40.84
G1X107.79Y39.33
G1X106.85Y37.87
G1X105.85Y36.46
G1X104.78Y35.1
G1X103.65Y33.79
G1X102.46Y32.54
G1X101.21Y31.35
G1X99.9Y30.22
G1X98.54Y29.15
G1X97.13Y28.15
G1X95.67Y27.21
G1X94.16Y26.35
G1X92.61Y25.55
G1X91.01Y24.83
G1X89.38Y24.18
G1X87.71Y23.62
G1X86Y23.13
G1X84.26Y22.73
G1X82.48Y22.41
G1X80.68Y22.19
G1X78.85Y22.05
G1X77Y22
G1X75.15Y22.05
G1X73.32Y22.19
G1X71.52Y22.41
G1X69.74Y22.73
G1X68Y23.13
G1X66.29Y23.62
G1X64.62Y24.18
G1X62.99Y24.83
G1X61.39Y25.55
G1X59.84Y26.35
G1X58.33Y27.21
G1X56.87Y28.15
G1X55.46Y29.15
G1X54.1Y30.22
M9
G1S0
M5
G90
; return to user-defined finish pos
G0 X0 Y0
M2
Update, reflashed 1.34 firmware, and no more error 2, now just the weak laser problem.
I can turn the laser on manually and it engraves/burns, but not when running a job, even at 100% power.
Try this please ben
IN console type
press enter
Tell me output
Then type $$
Do the same please, past the output
Btw, S100 is 10% power, remember S1000 is 100% in lasergrbl
Also what job origin was you using?
Output of $#:
[G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G92:0.000,0.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
$0=20 $1=50 $2=0 $3=0 $4=0 $5=0 $6=0 $10=1 $11=0.050 $12=0.002 $13=0 $20=1 $21=1 $22=1 $23=7 $24=600.000 $25=3000.000 $26=100 $27=2.000 $30=1000 $31=0 $32=1 $33=250.000 $100=80.000 $101=80.000 $102=80.000 $110=9000.000 $111=9000.000 $112=9000.000 $120=2200.000 $121=1800.000 $122=2500.000 $130=400.000 $131=430.000 $132=1.000 ok I am aware of the GPRL power differences that you mentioned. In lightburn you choose a percentage. For example I was engraving my leather at 40% per the reference manual, and my engraving turned out good. Now, even at 100% in Lightburn I get a very light line on cardboard, or leather. Did you see the video and picture I sent in a followup email? I've resolved the ERROR 2 issue. Link to youtube video of issue. Picture of settings in Lightburn for engraving on cardboard. [Weak Laser with Laser LED](https://youtu.be/4h-a_6xeL3A) ![20200903_235418|243x500](upload://exSweJcF9G7jYhUjig8AkPug9Jc.jpeg)
Seems aparent you had a loss performance on your diode
Also the dot size seems big, but hard to tell in video.
I got your email as well will reply with instructions for replacement
Thank you, awaiting instructions in the email. Just an FYI I just ran the laser at 100% with a speed of 30, yes 30mm/min and it wouldn’t cut through the same leather it cut through last night at 300mm/min and 100%. It barely scratched the surface. I’ve also adjusted the dot size following multiple instructional videos with the same outcome. I appreciate the quick responses!!!
