Art Library - Small Icons
Has anyone had trouble with the art library showing extra short icons no matter what the thumbnail size is? It only happens with one of my libraries, but happens on 2 different computers the same way. See pics below. “Templates” library is really scrunched. “Christian-Faith” is how all my other libraries look.
Capture
Can you email us the file (assuming it’s small enough)? I haven’t seen this before. If it’s less than 10mb, you should be able to send it to support at lightburnsoftware dot com, and include a link to this thread. Assuming I have power again at some point, I can have a look. :slight_smile:
Just sent.
I’ve looked at the file and the last 5 entries are corrupt. Do you regularly have multiple copies of LightBurn open and active? Prior to 0.9.16, if you altered the content of a library from more than one running copy of LightBurn, it would not sync correctly between them and would corrupt the file. 0.9.16 corrects this, forcing a check / sync whenever you activate the app.
