Asking for Help
When I started my laser machine, my laser tube fired the laser normally. But after a moment, laser light does not emitted from the tube anymore. Is anybody use to meet & solve this problem ?
Without more information, we cannot say anything useful.
Help us see what you’re seeing:
Thanks …
You can check what I mean via this YouTube video.
https://youtube.com/shorts/xj7e6Bx8oVg?feature=share
The beam looks normal when it’s on. I don’t know if the bright flash when it turns on is meaningful.
If it shuts off the same way while you’re holding the TEST button on the power supply (after unplugging the connector with the wires from the controller), then replace the power supply.
If that does not fix it, replace the tube.
I think that’s as specific as anybody here can be, given that we know nothing else.
Thank you for your answer. I am not sure what is the problem too. But the laser tube fire the laser light normally when I turn on the machine. But after a moment, the laser light does not come out from the laser tube anymore. We can see the light in the tube normally, but it does not come out as I show in the video.
