ATMSolutions C02 PRO35 MINI - able to connect on Linux only with sudo, is it intentional? (now with debug log)
EDIT: I succeeded after I used sudo, is it intentional or a hacky workaround?
I have access to a laser, but it is not my own so I am not allowed to flash it etc.
Noone even tried connecting with Linux or Mac.
People succeded with LightBurn and RDWorks on Windows.
Sole remaining ideas:
“is your user profile set up with dialout / tty permissions? If not, LightBurn won’t be able to see the USB connection.”
How can I check this? I see nothing in logs complaining about it, but I also so far failed to check this.
“Port open failed” hint - investigating Search results for 'Port open failed' - LightBurn Software Forum “Something is keeping the port locked - That’s why it’s saying “Port open failed”. It’s trying to connect, and unable to. LightBurn is finding the port properly.”
What I tried:
(1)
Automatic detection
I was trying to connect to ATMSolutions C02 PRO35 MINI via USB but LightBurn was unable to detect this device. Device > Find my laser was resulting in getting “Device discovery wizard” with empty device list.
log is at log on automatic detection attempt · GitHub - I see nothing useful there, but it seems that it at least detected something
15:47:15.938  D: Enumerating ports:
15:47:15.978  D: Port: "ttyUSB0"
15:47:15.978  D:       Valid Candidate:  true
15:47:15.978  D:       PID: 24577 VID: 1027
15:47:15.978  D:       Manufacturer: "FTDI"
15:47:15.978  D:       Description: "FT245R USB FIFO"
15:47:15.978  D:       System Loc: "/dev/ttyUSB0"
15:47:15.978  D:       Serial: "AC01LYBY"
15:47:15.978  D:
15:47:15.978  D: EV: 1019 took 1477444 uS
Laser was sole connected USB device.
dmesg shows device connecting:
[ 2443.532203] usb 1-3: new full-speed USB device number 11 using xhci_hcd
[ 2443.687063] usb 1-3: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
[ 2443.687072] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2443.687077] usb 1-3: Product: FT245R USB FIFO
[ 2443.687081] usb 1-3: Manufacturer: FTDI
[ 2443.687084] usb 1-3: SerialNumber: AC01LYBY
[ 2443.695143] ftdi_sio 1-3:1.0: FTDI USB Serial Device converter detected
[ 2443.695231] usb 1-3: Detected FT232RL
[ 2443.696229] usb 1-3: FTDI USB Serial Device converter now attached to ttyUSB0
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 04f3:22d7 Elan Microelectronics Corp. Touchscreen
Bus 001 Device 003: ID 8087:0a2b Intel Corp.
Bus 001 Device 002: ID 0c45:6715 Microdia Integrated_Webcam_HD
Bus 001 Device 011: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
sudo lsinput logs: sudo lsinput.log · GitHub
(2)
Manual config.
Ruida
Field of work: 500 x 300 mm
set rear right to 0, 0
Edit → machine settings
it gives “communication with controller failed”
(3)
First time users - welcome! - not useful as what is described there failed for me
I am running
LightBurn 0.9.20, built nie 2020-12-20 @ 01:42
Ubuntu 20.04.2 (Lubuntu to be more specific)
I am not using external hub, I connect USB directly to laptop.
I checked a different working cable.
I did sudo apt-get dist-upgrade
As far as I know I m using latest LightBurn.
I am not really interested in Windows version - I want to buy LightBurn because it has Linux support.
previous attempt Lightburn will not find my Rudia laser
This a new test on a new laptop, also on Linux
So far I failed to get even an useful error
One more idea: LightBurn binary started from command line, automatic detection:
./LightBurn
libpng warning: iCCP: known incorrect sRGB profile
connected
"Integrated_Webcam_HD: Integrate" "/dev/video0"
Found port: PID 24577 VID 1027
Product: "FT245R USB FIFO" on "ttyUSB0"
FTDI: Probable Ruida / TopWisdom (possibly GRBL)
sent 8
waiting for 18
Vend: 7531 Prod: 3
Vend: 1267 Prod: 8919
Vend: 32903 Prod: 2603
Vend: 3141 Prod: 26389
Vend: 1027 Prod: 24577
Vend: 7531 Prod: 2
sudo ./LightBurn
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
connected
Couldn't open preferences file for reading
QXcbConnection: XCB error: 3 (BadWindow), sequence: 898, resource id: 4218701, major code: 40 (TranslateCoords), minor code: 0
Port open succeeded
Vend: 7531 Prod: 3
Manufacturer: Linux 5.4.0-67-generic xhci-hcd Product: xHCI Host Controller Serial: 0000:00:14.0
Manufacturer: ELAN Product: Touchscreen Serial:
Manufacturer:  Product:  Serial:
Manufacturer: CN0PYJNXLOG007BAB0H9A01 Product: Integrated_Webcam_HD Serial:
Manufacturer: FTDI Product: FT245R USB FIFO Serial: AC01LYBY
Vend: 7531 Prod: 2
now it works (at least laser detection)
Trying to fire up a new Mini Gerbil - #3 by chaoticmind indicates that it is related to dialout permission
at the console just run the command groups
It should print out a list of groups your user is in, if you do not see “dialout” in that group, then run:
sudo usermod -a -G dialout ${USER}
Then reboot.
After that my guess is you will be able to connect to the laser.
