Hello I have a Atomstack A5 with a tinybee controller flashed with fluidCNC.
I am having issues trying to use my Atomstack R1 chuck (I have never got this set up proper yet)
I am running it off the z axis and in rotary setup I have the chuck selected I have been told to use 160mm/per rotation and set the object diameter or circumference to the right size.
I do this and hit test and it goes 1 full revolution around (mark to mark).
I mark the center of the “box” I want to engrave in on the item and line up laser. I have tried start from current position and I selected the center left position since I am lined up at the top center of the engraving space.
When I frame or send the job. it wants to rotate the item roughly a quarter turn and engraves there.
If I select start from user origin it does same thing.
Super frustrating.
If I engrave a 20mmx20mm box it comes out the right size just in the wrong spot… so the rotary setup must be right?
This is not good if the item has a handle it crashes into the laser or the table.
Any ideas?
