Sorry to hijack your thread. Im using the same machine on 1.1f . I have enabled laser mode, Do we control laser power from the “Cuts” tab, or is it through the S-value?
right now i have settings as $32=1, $30=1000
I have changed it in the cut tab, and it seems that no changes are made while in laser mode. Another question, anyway to make this machine slightly faster when laser engraving?
You control power through the Cuts entries. The S-value is the total available range.
Not sure what you mean by “I have changed it in the cut tab and not changes are made while in laser mode” - Do you mean you aren’t seeing a beam, or it’s not firing with any power?
For 3018’s, the only way to make them faster is to increase the allowed speed in the firmware settings ($110 and $111), but because of their very high micro-stepping rate (usually 1600 or 800) they’re limited by the 8 bit controller.
8-bit GRBL can only send step pulses at a maximum of 30,000/sec. If you have 1600 steps/mm, that means a max of 18.75 mm/sec (1125 mm/min). If the steps are at 800 steps/mm, you can get up to 37.5mm/sec (2250 mm/min). You would need to reduce the micro step settings on the step drivers to go any faster.
