I purchased Atezr P10 Combo. With LightBurn, the laser power is very low, but it works correctly on LaserRGBL. LightBurn values: $31 = 0, $30 = 1000. Thank you.
Another common cause of this issue with your type of laser is commanding your laser to run faster than its maximum allowable speed, leading to power downscaling.
Check to make sure you are using the same speeds in LightBurn as the other program, taking care to pay attention to the units you’re using - a given number in mm/second is much faster than that number in mm/minute.
You can read more about that here:
