Don’t follow your logic, why would they advertise 2300mm/s and set the machine to 1200mm/s as a maximum? Of course, none of these places stretch the truth.
If I have a 30mph governor on my car and the manufacturer says it will do 90 mph… would you say it will go 90? Maybe off a cliff…
Or maybe the hypotenuse rational? That doesn’t seem to work out either.
@Chris89 This is from the machines page…
Seems odd they’d claim 2300mm/s when the upgraded servo can only do 1500mm/s… I can see why it’s limit is set to 1200mm/s
From what I’ve read I find it hard to believe it can actually run 2300mm/s along the X axes.
This is in an area that Mel Brooks called ludicrous speed.
This is my machine…
My acceleration is 4.5 times faster with stepper motors… Of course I don’t have all the mass you have, but it’s acceleration values are actually pretty low, compared to mine…
Even it you could get it to work at these speeds, I don’t think it’ll do what you are expecting.
I set mine up to simulate your machine, using your acceleration values and raised the maximum speed to 4000mm/s, ran the preview on a 30mmX90mm box. I have a 5030 size machine, with the 30x90mm piece of material centered in the work area. The overscan already exceeds my work area… The green box is the work area. I had to zoom out of the preview to get all of the overscan visible.
This is the overscan running at 2300mm/s, takes a little over 7 minutes…
At 1200mm/s the time is almost 1/2 to do the same job, takes 4 minutes.
I don’t think this will ever make 2300mm/s
Just MHO…
You’re configuring it, it has no knowledge if it has a mouse in a wheel or a fast servo…
I hope you saved the original machines configuration before you starting changing things…
This whole thing has made me wonder.
I don’t think you are following me about the issues you’re up against, which is physics. You continue with the high speed visions, which I hope you see here, won’t work as expected.
We can only hope we’re missing something from Boss…
