Broken Glass water Tube on co2 60w Laser Tube
Hi, so my old 60w co2 laser tube died on me after a lonnnnng time of use so purchased a new one, on receiving it from the courrier it was damaged in transit one of the water inlet pipes had broke at the bend (see photos) the company had shipped me a new one but told me i can keep the broken one.
The question i have is can it be fixed? I was thinking of extending the silicon water pipe and using some silicon seal to seal it all or even some epoxy? What are your thoughts?
There is no way to do this that I’d trust. If it leaks while running are all your electronics underneath it?
Is this on the anode end?
There might be some way of hacking it, but I’d suggest not.
Good luck
I’ve tried the same with a 40 watt tube, it’s a shame that there are so many breaking in transport.
But, I repaired mine with two component epoxy (here they call the chemical metal), it worked fine for me. If there is no other (hidden) damage and you have some expertise with epoxy it is worth a try.
In the picture it looks as I fixed it while the tube is mounted in the machine, it was not. The tube hold tight and worked until it was “normal” old and worn.
If it doesn’t leak… it should be fine…
Thanks for the photos :thinking:
Yes its on the anode end! I was thinking there might be enough lip left on the glass pipe to get a good attachment with a silicone pipe and then cake it with epoxy or something! Ill give it a go and connect up the water chiller and just let it run theough and see if it leaks.
You can also pressure test the tube with water,…after you repair it. Install a valve at one end and close with a plug or a valve, at the other end and pump up the tube with a little overpressure, 0.5 bar is more than enough to test and above what our refrigeration machines deliver. Let it stand with pressure on for a few hours. (Obviously not in the machine;-) )
Instead of trying to put epoxy around the silicone tube and glass I’d suggest trying to build-out the broken portion of the glass, allowing you to attach the silicone tube in a normal way.
  1. thoroughly clean the glass
  2. carefully file down any hard edges that might act as a stress point. There may be some benefit to lightly abrading the glass where the epoxy will be applied
  3. insert a well fitting cylindrical object down the middle of the glass opening to serve as a form. Apply some sort of mold release or release agent to it as you’ll be applying epoxy against this piece.
  4. carefully form the epoxy over the form ensuring good bonding with the existing glass substrate. Do your best to conform to the existing shape. Be generous with the epoxy.
  5. allow the epoxy to partially cure, then carefully remove cylindrical form.
  6. allow epoxy to fully cure
  7. pressure test
  8. profit
Thanks for the advice.
Sounds like a good idea ill give it a go
Or locate a local glass blower shop. They can fuse a new tube to the broken area. Of course, this does not apply if the tube is quartz glass.
I’ve heard of laser tube repair shops that can do glass repair. However, they’re typically working with medical grade or industrial lasers tubes costing quite a bit of money. The ones I’ve seen won’t even look at Chinese commercial tubes. Not likely economically viable especially considering this is meant to be a cheap freebie at this point.
1.165 / 5.000
Hello colleagues and nice to meet you!
I am new to your forum and thank you for accepting me in your community!
I received a 60W JULONG Laser from a friend, the device looks very bad, unmaintained and rusty.
I also have a 40W laser and I am not exactly without knowledge in the field and after I received the device I started cleaning it, oiling it and now it looks much better. The problem that seems to me the hardest is the fact that in the front part of the tube where the laser beam comes out, there is a brass piece through which water passes (I hope I can post pictures, or I know how to do this…). So that brass piece must be soldered and from what I have read on this forum this operation can be done with a bi-component resin. I read among the recommendations that a good option would be J-B Weld, in my country I find the J-B Universal option, is it good?
I hope to succeed in this repair operation and I will come back with other opinions after the rest of the tests and I will ask for advice from those who are more skilled and who will be willing and patient to help me. I receive this advice with openness and for which I thank you in advance!
P.S - I can’t manage to post photos unfortunately …
welcome to the forum.
I have repaired the front part once with normal 2 component plastic padding, it wasn’t very nice but worked fine.
Thank you very much for your opinion ! I’ll try it too .
