AntoRoni
(Anto Roni Roni)
December 31, 2021, 1:13pm
1
I noticed a bug in lightburn, when going into the device settings and making the changes (laser control inline), when saving the gcode everything goes fine, but when I close and open LightBurn again, and save the same gcode, without going into the device settings window, the Gcode is saved as M106/M107, instead of using the inline settings I had made.
Therefore it is necessary, whenever you close and open Lightburn, enter the device settings window, and check the laser control Inline option.
berainlb
(PY)
December 31, 2021, 1:22pm
2
This is the same observation from another topic:
Since the update to the current version my laser control command setting to Inline not set in gcode and replaced by M106/ M107 commands but Inline is set!
Then I am forced to go to the settings and set to M106 or M03 and back to Inline to get the S Values in the G moves again in the exported code.
Even after an update from 1.0.04 to 1.0.06 the same issue exists.
This is a bug and not a feature
Do you happen to know which version of LightBurn when this started?
Adding @LightBurn here for visibility.
AntoRoni
(Anto Roni Roni)
December 31, 2021, 1:38pm
3
This started since V1.0.01 , so in V1.0.00 this doesn’t occurs.
@berainlb @LightBurn
Are you connected to a laser when you save GCode?
AntoRoni
(Anto Roni Roni)
December 31, 2021, 5:14pm
5
No, I just save without connect with the laser.
Ok, then I believe that is the problem, and I think I’ve fixed it.
AntoRoni
(Anto Roni Roni)
December 31, 2021, 10:12pm
7
Ok, waiting the new release.
Yes, as I said - I think I fixed it. I can’t rush a release out the door before it’s ready, so you’ll have to be patient.
Rick
(Technical Evangelist)
January 3, 2022, 9:14pm
10
LightBurn:
We are fast, but not that fast. Fixed, but not out just yet.
We have not produced a new public release with this fix. You can follow our release announcements here: News - Development updates and bug fixes – LightBurn Software
system
(system)
Closed
February 2, 2022, 9:14pm
11
