I burn rubber stamps using the Snapmaker 2.0 and 10W laser. Artwork is generated in Illustrator, imported as PDF into Lightburn, layer is configured to use 0.24 ramp length, GCode is exported to the machine. This has worked correctly for half a year from v1.2.01 and earlier. I could previously “see” the ramp in Preview with Shade According to Power enabled. In v1.2.04 the ramp is simply gone from Preview and does not burn when exported as GCode.
