Hi:
Does anyone have or know where to get a burn test chart so that I can test the laser and all different speed and laser power rates. I can draw one but was wonder if one is already available.
I started creating one with 72 squares with values for the laser percentage from 10% to 90% and speeds from 50mm to 400mm. But I don’t think the software does more then 29 layers.
Thanks
I’m not able to answer for a location of a pre-fab burn test, unfortunately.
On the flip side, you’ll note that there is a power factor setting for selected items in Lightburn.
With the shape properties panel open, select an object and change the power level in the properties panel.
Note that, for example, if your layer power is at 50 percent and you change the shape properties to 50 percent, you’ll get a true power level of 25 percent. All this on one layer!
This is what you are looking for I think:
Thank you, just what I was looking for
