Material Cut/Scan Test Files - Power Scale
UPDATE
LightBurn now has a very powerful material testing tool built right in! Find it in the top bar menu under ‘Laser Tools > Material Test Generator’
Please check out our documentation for a full run down on all the features: Material Test - LightBurn Software Documentation
If you’re here specifically looking for the manual material test files and instructions, click the arrow below.
Expand this section to see manual material test files
Here is a test file created using the ‘Array’ and ‘Power Scale’ features. (you must adjust the settings in this file for your setup and needs)
Setup grid array with all rows at 80% Max pwr 0% Min pwr. Set each row at different speed starting at 400mm/s down to 100mm/s from top to bottom of scale.
Viewing left to right, each column uses ‘Power Scale’ to adjust from 10% to 100% (of 80%).
PowerScale Test_01_Rico.lbrn (23.7 KB)
Downloadable Power Spectrum
Material Settings for Acrylics
Power Scale Help
New to Laser Cutting and Looking for Some Advice
Trolase Materials settings with red/black 100 W laser
Burn Test Chart
Cut Out Settings
Cutting plywood
How do I create a table of powers/speeds?
5500mw laser how to work in lightburn
Grayscale Setting Question
Define speed/power per shape for test card
Image engraving
Laser Master 2 Material Help!
Speeds for cutting
Power scale - Max power issue
To write text on wood
Has anyone created a file for a test board with different speeds and power settings?
Laser Calibration Help
Engraving Portrait - plywood poplar
Changing the cut powerscale
Newbie setting the origin / start point
Max number of Layers?
Speed in percentage
K40 on greyscale
2 questions, 'table grids' as well as 'test patterns',
Trying to create greyscale / dither /stucki
Part of Graphic Lighter than other parts
I cant get my laser to cut wood
Cutting with Atomstack
Cutting parameters with AtomStack A5
Low power.1 still cutting through
Two trees totem S 40W, engraving/cutting speed and power info needed
Engraving slate on atomstack a5 pro
How can I engrave 2 different power levels in the same pass
Tips on optimizing fill settings?
How can I add more layers
Help getting started: Mac & Atomstack A5 Pro
How to laser engrave a sentence in LB
Newbie, not too clear where to go
Can I use to just engrave?
Power scaling not working and staying consistent no matter the power output
Little bit lost in Laser Speed Settings
What a type of diode laser?
Set ONLY the speed to all the layers in one time
Not burning the wood
Emblaser 2 will not cut or etch
Adding more layers
Feature request: edit number and color of layers
Creating a gradient chart- Bug?
Material test question
Option fill the laser does not go ON
Radiused coners on a box
Unlimited Layers: Feature request
Problem with Fill+Line in text image
New user questions - TIA
Trouble fill-engraving small-ish text, weird engrave artifacts
Cut Out Settings
Thanks for sharing, Rick.
Do you happen to remember the “real world” amount of time it took to run (since the LB estimate is often not accurate)?
If I load this file in the soon to be released “New Simulation” preview, I see that the total time is 44:07:3 based on my current cut order.
The new simulator is covered in a bit more detail here: Total time estimated issue
Thanks Rick saved me some time :+1:
How did I do with my estimate? You can double check my numbers for yourself now with the release of 9.00. :wink:
I’m still having a bit of trouble grasping the 100% power versus the amount of power I can select while still keeping my mA usage below 18.
On my 40w K40 the max I can set it is around 70% in order to keep it below 18mA draw. When I select 5% power on the laser I get nothing. Should I be tweaking the $ setting somehow in order to make 70% on my system equal to 100%? Or should I just keep things as is and not go over 70% when engraving?
The potentiometer dial or electronic control of power on the machine is the hard limit, no matter what software tells the laser to do.
It is attenuating the 0-5v signal that is coming from the software, it is not possible to overdrive your laser this way. 18ma seems like it might be high for a K40 should be more like 12ma I think.
So, another way to think of this is the software is always going to output 0-5V based on what power level you set between 0%-100%.
The attenuation of the dial scales that voltage down, so if your dial is set to max out at 12ma, then the 100% 5 volt signal from the software is going to be reduced to the voltage that tells the laser to fire at 12ma.
It’s like a brick under your gas pedal in a car, change where the brick is and you can only push it that far.
I have searched the web, and this site, but I cannot find out what the ultimate max current rating I should run at (or not exceed to maximize the life of the tube) I have a 80 watt Chinese laser.
Ray
So if the potentiometer on the laser is set to 15% and I select 100% in the software it will not output more than 15%?
My ideal setting of the pot should be 70% or whatever I want my upper limit to be?
Correct!
The software has no idea what the potentiometer is set to and is always outputting 0-5v scaled to the percentage you specify for the cut/raster.
The max milliamp rating is a specification of the tube manufacturer.
There is a minimum amount needed to start lasing as well.
The best thing to do is test from that minimum up to where the power level doesn’t increase the depth of cut anymore. That will typically be less than the maximum power rating the tube manufacturer specifies according to what I have seen from Russ on Youtube.
I highly suggest you spend a bunch of time watching his videos and learning more about the whole process, it will help immensely.
https://www.youtube.com/channel/UCqCyShJXqnElPTUnxX0mD5A
The exact number will depend on the manufacturer and model number of your tube.
My 80w red&black has a EFR model F2 tube in it. (says so on a sticker on the tube)
A quick look at the EFR website says maximum current of 28mA and “max current in long term operation” of 25mA or less.
EFR website: http://en.bjefr.com/xsproduct_EN/TypeId-368.html
For my particular tube/power supply combination, 28mA is about 80% indicated power and 25mA is about 70%.
Thank-you both for the information. I will look at the tube when I get home tonight and see if I can find a model #. Doing the research on Lasers, before buying, I had set the max to 80% as soon as I got it, but have always wondered if it was too high.
Ray
Hi,
I modified the file slightly for my needs and machine but here’s my output
2.5 W diode @ 445nm
I to have a 2.5W and would like to test this out. Did you base your settings of 10%-100% off of 100% max power?
Yes 100% of the 100% (full power)
Savardi, wouild you mind posting your laser scale?
Download the one at the top of this thread snd adjust it for you. I’m not home currently but can try to upload mine in 2 weeks (travelling).
Power:SpeedFill.lbrn (50.7 KB)
Thank you for this @savardl! I was looking for something just like this to run on my 2.5w as well!
