I’m totally new to laser cutting. I bought a Sculpfun S9.
Did my first cuts, everything is working fine.
But now I want to make some test cards but I’m a bit lost in the laser speed settings.
I tried this one
Speeds here go from 100mm/s to 400 or 500mm/s.
But is this the real speed the laser moves ? 500 mm / sec or 30000 mm / min seems a lot to me ?
I looked up the max speed for a Sculpfun and it is about 3000mm / min
So I would think 30000 mm/ min (500mm/s) is maxed by 3000mm/min
But then the 400mm/s should also be maxed by the max speed and should give the same result but this is not the case
I believe that power grid is more suited to a Co2 system. You could try this one which should be better for a diode…I hope. Power Scale 10-100 and 500-4000.lbrn2 (61.4 KB)
