my images are burning mirrored did i set something wrong plz help
You have very likely not set up your laser correctly, try to look under “Docs”, there is a nice setup guide.
i will look thank you
is there place i can get the hole list on this <Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:100,100,100>
[HLP:$$ $# $G $I $N $x=val $Nx=line $J=line $SLP $C $X $H ~ ! ? ctrl-x]
… it should not be so difficult to change the direction of your machine. Is everything else ok ?, do you have end stops, where are they located ?, Have you set the machine to absolute chords? you can print your $$ and post it here.
