I started burning this and plan to cut it out for a later project. when it started it went back and forth on the X and moving up on the Y. Is there any way It can move along the outline and decrease the run time?
Most likely, but we need to see what âthisâ you are trying to produce. Please share and show us what you are trying to do and we can go from there. ![]()
As @Rick suggests itâs impossible to tell exactly what youâre after but based on your description it sounds like you may be asking about offset fill.
Read this topic from yesterday and see if it matches what youâre looking for:
Following a path rather than flood fill - LightBurn Software - LightBurn Software Forum
Not for an image, but if you do a âTrace Imageâ first, the result will be a vector, and you can then use the Offset-fill on that.
ok so I load the image to within the border then where do I find trace image in Lightburn?
thank you, I will give it a try
GIve it a try but I suspect based on the geometry of the image youâre trying to burn that offset fill probably wonât be a great fit. I believe offset fill is intended more for concentric shapes.
Explore âFlood fillâ as an option. You can find it under the advanced tab of a fill layer setting.
This also requires a vector graphic.
I have a planer if I am not happy with it, and I will experiment with it more.
Always good to learn something new.
And there is the menu system, of course. Our documentation is searchable, so this is a good resource to have handy as well.
