I don’t know alot about gcode. Does this mean anything, bad?
It means that you’ve commanded the laser head to move to a position beyond the physical defined limits of the machine.
The easiest way to avoid this is to use Absolute Coords for your coordinate system. It’s found in the Laser section of the UI (lower-right).
