@gunnyb Customer used Lightburn ver 1.708 and there is no panning issue. When upgrading to any 2.0x version the camera automaictcally starts panning abck and fourth.
Laser is Xtool S1
Current setup:
Mac mini, Chip: apple M4
Memory 16GB
macOS: Sequoia 15.5
Camera mounted on top lid of laser
Here is a link to a video showing the propblem
Any ideas? This only occurs when gogn from 1.708 to 2.0x. Mac OSX photobooth works perfectly.
Standard ELP 16mp 4k camera, I have used on 60+ other installations. I’m having him try changing the FPS settings, have no other idea, especially as the camer works fine with native apps.
Key Specifications
Feature Specification Source
Sensor 1/2.8" Sony IMX298 CMOS
Max Still Resolution 16 Megapixel (4656 x 3496)
Max Video Resolution 4K (3840 x 2160) at 10fps (MJPEG)
Lens 180-degree fisheye lens
Field of View (FOV) Horizontal: >180°, Vertical: 152°
Frame Rate 10fps at max resolution; up to 30fps at 2048x1536 and lower resolutions (MJPEG)
Connectivity High-speed USB 2.0 interface
Compression Format MJPEG and YUY2 (YUYV) optional
Operating System UVC compliant: Windows, Linux, Mac OS, Android, Raspberry Pi, etc.
Power Supply USB bus power (DC 5V)
Adjustable Parameters Brightness, Contrast, Saturation, Hue, Sharpness, Gamma, White Balance, Exposure
Dimensions 38mm x 38mm board size
Going to 180 degrees and beyond will cause issues like this. The math in openCV kinda breaks when this happens.
You may have had success before with different lenses that don’t cross that 180deg threshold, either by manufacturing tolerances being on the less-than side, or simply a lens that isn’t as rated on the box.
While that may be, @JediJeremy can probably shed some more light on this, but as a rule of thumb, 180 degree-ish cameras will have poorer performance and may not calibrate at all. The camera system is going through major updates between 2.0 and 2.1 and I’d recommend moving to a lower fisheye lens for future installations - you’ll get better results anyhow.
Then your next best option would be raising the camera mounting position, or opting for the head mounted camera.
LightBurn 2.1 also has support for IP cameras, and I suspect (like with the P2 and P2S) we’ll be able to pull in the camera streams from the xTool S1’s native cameras.
ok, the camera is mounted to the lid at the heighest point to get the whole bed . I hope they continue to work, as they worked flawless until this one instance for more than a year and a half, when i first started down this path.
We’ve just replicated this in LightBurn 2.0.03 with the same camera module, and are investigating further.
Edit: It appears that this doesn’t occur when selecting a frame rate other than 1fps, so for the moment, the suggested workaround is to go to Edit > Settings > Camera tab > Set camera framerate to something other than 1fps
yes, I can confirm that my workaround of choosing 10fps seems to have worked and fixed the jumping around. I have been using 2.0.03 w/o any issues with the camera jumping.
