Camera, Variable Text; and Edit Issues
HI!
I’ve been running an LC-60A for years with no real problem.
For some reason I decided to change the Home Position from Front Left to Rear Right. The LC-60a doesn’t have a limit switch on the right X axis so it hit the corner and made those grinding noises. Long story short, everthing got messed up and I basically had to delete the settings and start over. Upgraded to V 2.0.02 in the process.
In the Edit tab, I no longer have Machine Settings or Device Settings available. I have let Lightburn find my laser and I have configured it manually, but the Machine and Device options are gone. Is there any way to get those back?
Every time I open LB or start a new project, the Camera and Variable Text windows automatically open, even after I have unchecked them. Isn’t there some way to keep them closed by default?
Thanks1
The Device and Machine settings now hide in the Laser Tools menu:
The program framework change in 2.0 has introduced a variety of UI problems. You can try RC-3 to see if it improves things, but it also includes some other problems that may be troublesome:
You can install RC versions “beside” whatever release version you’re currently running and they will should import the release version settings.
