Camera zoomed in after update and calibration
Hello, so I have a phecda 20watt laser cutter and a Geeksatlarge camera set up. It was working fine until I did an update today now it overlays a very zoomed in version of what the camera is seeing.
I’ve recalibrated and tried to do an automatic burn adjustment but for some reason it only burned in the targets and not the scan code blocks. It went through the motions but the laser intensity seems to drop to almost nothing when it moves into burning those specific marks.
So I tried the manual adjustments with the targets set at 380mm X & Y (the bed is about 400x400mm.) Still didn’t work.
I’m not sure where to go from here. I checked the forum and I several of these complaints but no solves? There was on that said the adjustment and it righted after rebooting but it didn’t seem to help my situation. Any advice is welcome as I am losing my mind.
No one on here has any advice?
This might help get you started. I do not use the camera, so I am not much help.
Thank you for the reply, unfortunately this didn’t remedy the issue. I do appreciate the help though.
