You can use any IP based camera. You just need to use an application like ManyCam to emulate it as a Web Cam.
-or-
Another example is I use a program called EpocCam Pro on an old iPhone 7 Plus that converted it to a WiFi connected web cam for me to use in my home office. It too works with LightBurn and shows as an available camera. So the choices are available to go beyond USB.
I think the bigger challenge will be finding an IP based camera with 110 - 170 focal length. I have a few hikvision cams around here. I will show you it is very easy to use ManyCam to port them in to lightburn.
Nice, thanks for the information! Yeah, finding a small wide-angle IP camera seems like the next challenge.
I start getting a little angry just thinking about IP cameras. I have dealt with so many awful Chinese-made cameras with absolutely horrible documentation (as recently as the new security camera I put up two weeks ago) that I don’t think I’d have it in me to try this without a good starting point. Knowing that this application will do it makes me more inclined to try.
Ah, well those numbers are not going to help as they are for a different size bed. I will update the image to relevant data if you give me your bed measurements.
You can also find this from the ‘Help’ menu in our trial version. If needed, we can extend the trial if you send us the trial key in an email to support at lightburnsoftware dot com.
I have a few posts that will help, but having the system in-hand, so you can measure from your chosen mounting location. This will provide you the best result when selecting.
All camera varieties are back in stock. Note: the 8MP 95’s and 110’s are no longer available from our supplier, but we’ve found very close replacements - almost identical specs, but slightly different lenses (now fisheye). The 8MP-85 replaces the 95, and the 8MP-120 replaces the 110.
The camera mounts for these are very slightly different due to a taller lens base, but those changes have already been made, and any mount you purchase from us will fit these cameras. The STL’s on the site have been updated as well.
