Can I use Y and a rotary axis instead of of X + rotary axis?
Hi,
I usually use X and A as the rotation axes.
So the chuck is in the same direction as my X axis.
But I have more room in the Y axis direction so I could use larger materials that way.
If I could select the Y and A axis for rotation it would work IMHO - but I can’t find any settings.
Is this possible somehow?
Check if this topic helps.
Change your scan angle from 00 degrees to 90 degrees. I get much better rotary results with this direction that I do with x axis.
That works - great !
I was looking for an option in the rotary setup dialog, did not expect to find something in the general setup :slight_smile:
