- List item* List item
Hi Tom,
I just assembled my D1 Pro and am running it with Lighburn. You will need to first download, BUT DO NOT TRY TO OPEN, the Xtool configure file…
https://support.xtool.com/hc/article_attachments/7316804567447/xTool-D1ProV3.lbdev
When LB first opened it brought up a window, make sure to select the lbdev file you just downloaded and it should configure. If you have the 20W. there is a wonderful person who shared their Xtool D1 Pro 20W materials library… its here in this forum. IT IS A LIFESAVER and will stop you from catching things on fire because the materials data sheet Xtool gives is for their software, not LB. I hope this helps.
Xtool D1 Pro Material library (rename .txt to .clb) 5W, 10w, 20W - LightBurn Hardware Compatibility [OFFICIAL] / xTool D1 - LightBurn Software Forum JUST FOLLOW THE INSTRUCTIONS AND RENAME THE FILE IDENTIFIER TO .CLB
Its a great start… you will have to tweak all settings of course.
