Can the Cut Pallete Settings be set Permanently?
Can the Cut Pallete settings be set permanently? and NOT let the projects overwrite the Cut Pallete?
Or at least an option to turn this feature off?
You can enable “Load default layer settings on new or restart” in Edit->Settings->File Settings.
ok… I was hoping to save my own settings. :frowning:
You can. Set the defaults to what you’d like them to be for each layer.
You can save them into a library for different materials then load those settings into different jobs for different materials.
Too add on to @berainlb comment, you can set them here…
