Since updating LB, I can’t choose anything but “Controller settings” as my origin for a job. The machine homes correctly, and the controller is set to “machine zero” as it’s origin, but it does not behave like it did prior to the update.
Sorry for the confusing response. Upon a closer look and reviewing the UI, I see Oz has changed this behavior for the Trocen / AWC device profile. I know there were differences from the way Ruida provides access to control job origin, but was not aware he made the change in the UI. Will need him to jump in on this one, we can both learn at the same time.
Sadly it’s not working the same as before for me. No settings have changed on the controller, yet no matter what I do in LB I can’t get the job origin back to 0,0.
What model of controller do you have? I just tried it on my LO-X7 and the job started at 0,0 (top right for me). I had to set the Job Origin in LB to top right as well and it started cutting from 0,0
My issue is that I don’t want it to start cutting at 0,0 as that is off my z-table. I need the job origin to be at 0,0 so I can place the cuts/raster where I need them in the workspace.
Right now with the origin being forced to the corner of the cuts instead of the workspace, it begins it’s job off the table.
Trocen has never supported the ability to change the origin settings from software, so you need to change the settings on the controller itself. Having the other settings present was a support headache because they didn’t work. It sounds like one of the options was giving you a behavior you wanted, but it wasn’t intentional.
I tried soft origin and it seems to do as you described. I placed a shape in the middle of the work area in LB and the laser cut the shape in the same position.
I have always used current position before today so I was not familiar with Soft Origin.
The takeaway for those of us using Trocen controllers, if you were using Absolute Positioning in LB, it looks like Soft Origin on the controller gives the same functionality.
