When I create an object in light burn, say I’m making coasters, I make the size roughly around 4" but when i send it to cut it cuts the object at approximatley 6"… can anyone advise? TIA
Welcome and thank you for posting. You will need to share a bit more about what you have. I see you list only “le4040” as your machine in your profile.
This is a good post, worth review: How to ask for help.
This sounds like your steps/mm are wrong. Has it always done this or is this a new thing. There are a few posts on here that explain how to calibrate the axis.
https://forum.lightburnsoftware.com/t/how-are-steps-calibrated/1690/4
Cheers
David
