Hi I can’t find a button that enables my laser to turn on.I can’t fire up my laser
If you’re looking for the Fire button, it only appears for diode lasers, per this discussion:
If you’re looking for something else, tell us a bit more about what you’re doing …
I have a 50w c02 laser and can’t find how to enable it.the rest of the machine works fine
Draw something simple, like a square, on a layer set to a plausible speed & power level, then send it to the laser. What happens?
If “nothing” happens, then upload thate *lbrn2 file so we can verify the settings.
Did you turn the power up on the console?
Yes.I have solved the problem it was the software my Computor didn’t like LightBurn. $188 down the drain
There are people using all the typical operating systems on all types of computers with virtually every comparable laser. If you ask for help with installation and configuration, there’s a high probability that we can get you up and running.
Thanks My machine works fine now,i will try Lightburn again when I get family with this machine
