I am trying to use the new Center Finder feature in Lightburn. After I move the laser to the three points for calculation and then select “Jog laser to Center” I get a message “unable to jog laser to center”.
I am using a SnapMaker 2.0 A350.
Is there something I need to set before I can use the “Center Finder” feature?
So that happens when the wizard calculates a center that exists outside the “workspace” of your machine. It is important that you home the machine and set machine zero where your workspace’s zero is if it does not have home switches before starting the wizard.
